Home. For those thats keen, Mitch (the guy with the camera) from last night is organizing a lil cruise to Wellington Point tonight. Meeting point's at Clive Peter Macgregor along Kessels road. Will start around 7-7:30ish.
pffft... who does fun things i mean really. I'd much rather work.. no wait i got that wrong
Well... Colin and I are going. Still waiting for Adam and Michael to reply.
Colin just wanna drive as much as he can.
MICHAEL! REPLY MY SMS!
Your missing out... Work ftw :blink:
ewok
Wuuda, chee ah goba fenga wah. Ewoks ftmfw
I got a Christmas party on Sat night .... free drinks FTW
Got one tonight and sunday night. Double free drinks ftmfffw
Ahh! No wonder it didn't work
thats what she said
(In the tradition of this thread....)
Thristian, you find the build of the 380 rwkw s15 owned by that asian dude?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
