Theres about half a dozen scattered throughout this thread, courtesy of John
Mang i don't have time to read through all of it, wears out my eyes. Can't you just send me one...
Couldn't have said it better myself.
...4 hours left :ph34r::)
4 hours I wish. I'm so royally f**ked atm lol. I really should stop posting n focus 100% on work but I'm slipping into holiday mode lol.
how long you got for holidays ?
I start work in three hours joy
14/12/09 - 5/1/10
Should be good
damn
Sucked in lol. I thought you would of had them saved to your comp Martin. John will appear in a minute with pictures it always happens.
14/12/09 - 5/1/10
Should be good
going anywheres for hols ? hurry up john sheesh
14/12/09 - 5/1/10
Should be good
You've got an extra week on me, b4stard! I don't finish up till next friday, and it seems each day untill then is going slower :ph34r:
They're in my sp4nk directory at home, but not here at work
What should I have for lunch?
I'm going to have "Grilled Chicken Breast Indian Style" :)
mmmmmm, breast....
Manging mangy mangeness.
Yo Mr Mang you down the coast now yeh ?
mmmmmm, breast....
+1
Roast Lamb and Gems FTW!
Yuuuuum I had toasted ham, cheese and salami for lunch today :)
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
