any1 wana buy my Tein HR coilovers, been told very good for drift and circuit cars,
i neeeeeed monies so if you or your mates or your mate's mates need coilovers tell them to check thread
http://www.skylinesaustralia.com/forums/Te...rs-t299161.html
rarrrrrrrr whats everyone doin tonight? Considering harrys/chapel hill but I can't be up late tonight so trying to work out if its worth going for the hack all the way over there :D
No. You tried to change Thursday again, and everyone ignored you. Again.
:D
Erm... no I didnt. It was colin that said Lobster > Baskin... like I said, I've had me earlier on the week.
Idling around 2000rpm!??!?!?!?!
Tristan: That tacho reminds me of mini...
John: Get back to your assignment and get your arse to the wash tonight! Quit slacking!
Oh yea. Its Harrys night again this Thursday. If you're gonna be working around the northside (Thristian), should we just make an exemption this time and go up north instead of icecream! Chicken Parm FTW!
Erm... no I didnt.
Don't lie to me Brandon. It's like playing with my emotions. Which are already in a fragile state with the car playing up :D
Not gonna happen dude. Still getting pounding by this assignment. Ass is quite sore
John: How much you want for that fuel pump? I found out that it should fit fine :(
Not sure what they're worth second hand? $40 and some cupping reasonable?
Dave sold me his for like $10
Lol, there you. I've seen ppl sell silvia ones for 60-70 and thought 40 was reasonable for an r33 one. When it comes to forum members I'd seriously hate to rip them off. $10 + cupping and it's yours Isola :( . I can help you put it in too if you want, but that'll be more cupping
thats cause im the nicest. on another note... do you approve josh? finished 1 side 1/2 way through the other.
also got a question... pods or no pods?
and yes i decided to run the skirts, they look baller. :(
Now that sounds like a deal that can't be beat! And when would you be free from your hectic assignment life to assist with said install?
Well looks like I'll be getting raped for the rest of tonight and tomorrow by uni. Saturday I'm going to the drag day. Sun, mon and tues will be work which means Wednesday at the earliest.
hmmm... might have to tackle it myself then. when can i come get the pump. and from where?
Time to come down south! John lives just 5mins from my place... Hahaha.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
