That is not nearly enough nuggets. You need to double your nugget intake asap. In other news our computers are down at work. Apparently they sent us an email regarding this during the week but I can't remember any so here I am at work with nothing to do and not even any internets to whore off properly. I think I'm just gunna go home...
So you've got no internets to do interweby things :)
I just lost didnt I ?
Will do, next nugget order
LOL
Do it. You know you want to
You lost the game
F*CK!
Damn your oiley hide..
What would be causing my idle to adjust a lot ? It sits on 2000 then it'll drop to 900 odd then up to 1000 down 900 up 1200 up 2000 down 1000. It's all over the show :)
Dirty or a non properly connected afm?
Maybe its just old :)
See you at the drag!
Its God's way of telling you that you should be going.
So i felt like some nuggets last night. Went to KFC, ordered my 18 nuggets in the drive through, get my box of goodness and go. When I open said box, there is no nuggets in it and instead: 4 wings >_< . Debated for a bit whether to just eat the wings, but in the end principal, and the fact i really wanted nuggets, won out so I went back. Found the manager "whas goin on here breh?". He goes off his tree at the drive though bloke (which immediately made me feel better :) ), then goes and gets me nuggets, and tells me I can keep the wings as well. Plus there was about 25 nuggets in the box, and they were all fresh. Win.
epic epic win
i love this
@Tristan: Ute may be at cooroy on monday. I'll try and arrange for it to be left at petrie, but no guarantees.
you're killing me, but i can work around it
ps like my new pic ;)
Bunta:
As for rb25 NEO into a ceffy, you should get onto Kev Rowley, send him the loom and he will make it work for your application, smity got kev to wire in his 25 for his R31. Very good guy and very cheap work cause he's a retired man. Also owns a very cool VG33 powered 120Y
Cheers Mate i will suss that out!!
What would be causing my idle to adjust a lot ? It sits on 2000 then it'll drop to 900 odd then up to 1000 down 900 up 1200 up 2000 down 1000. It's all over the show >_<
AFM related, so broken AFM/wiring or and air leak
+700
oops forgot to log Anna out
Thanks for that will investigate. If it is a AFM what's a good one to replace it with ?
Just get a PFC d'jetro and f**k the AFM off . . . lol
Edit - Or a vi-pec >_<
unless you have a aftermarket ecu use a rb20 or series 1 rb25 one for a series one or a series 2 rb25 or neo one if you have a series 2
gah i really need to remember to log Anna out
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
