HAHA yeah I recon we get away with a fair bit aye
We're not all c*nts :cool:
This obviously turned into a whore thread so personally I treat it like whoretown. Actually you farkers whore this thread more than the rest of the state whores the 'real' whoretown lol.
TBH this thread should really merge with whoretown...
We're not all c*nts :)
Hahaha
Nah I like all the admin on this forum, Its good how you get involved in the never ending whoring and ridicules/awesome convos . . . lol
*nods*
Hahaha. Considering we've even got guys down the coast whoring here!
You knw it brotha from anotha :D
P.S - Gold Coast FTW :P
NNNOOOOOOO! No merger! This thread is epic win
*nods*
-1
+1
I just smashed my omnia HD on the tiles, FML i really hope i remembered to get insurence
Massive LOL
Oh noes, ouch!!
I might have a spare phone lying around, it'd be nothing flash but if you're stuck without one you're welcome to it
Oh noooo that sucks
PS: Dan, yes its a picture of "I see what you did there"
HAHAHA
Work pc = epic fail
Yeah read about that earlier, deceitful pricks.
The thing they don't understand (or care about) is that it's not about people wanting to look at kiddie porn or bomb instructions or whatever... it's about some pen-pusher pretending to be our mums, deciding what we can and can't see.
IMHO...
If you're under 18, it's your parents' responsibility
If you're over 18, you're an adult and can make your own choices
If you *do* look up something illegal, then you should be punished accordingly
Farken left wing evangelists, get back in your Prius, hug a tree, pat yourselves on the back and GFTO of our internets!
Thats exactly it Revhead. I have no desire to look at CP or bomb instructions, but you can guarantee there will be scope creep with something like this. Before long, everything the gov't doesn't like will be censored.
In my opinion, the government is spending FAR too much time and money trying to do parents' jobs for them, which in turn makes parents less responsible, and thus worse parents, so the gov't tries to do more, etc.
We are rapidly coming a police state where the gov't decides everything we do, and I don't like it.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
