@Colin: Whats the details on the TPG plan you are on breh? all the non naked plans seem to just be $10 less than the equivalent naked plan, and you can't rent a phone line for 10 bux...
correct me if i am wrong, but for a naked plan, you have to have a phone line when you connect, but then after that you can disconnect the phone.
correct?
correct?
Yes, but according to the Pom you get a lot more for the same price if you DON'T go naked. But that just doesn't seem to be the case from what I can see...
I need to get internets sorted out for the new place.
For Colin, RE Tekken 6
-snip-
Hahahahahahahaha. I was playing tekken something yesterday against someone who actually knew how to play. Got my arse kicked :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
