and another!
Aussie Aussie Aussie! Oi Oi Oi!
EDIT: Oh and it was the actual batsman too! just 2 tail enders to get. Piece of piss.
Edited by Smity42
Since its been on sale for so long. I'm sure you'll be able to get him to provide rego or rwc too. Dropped the price by a fair bit there. If he's imported that himself, get him to provide auction sheets (not that it means anything but at least you know what sort of auction grade that is) etc. I'm sure he would have a copy of the import approval papers from compliance workshop too. I got mine from imperial auto when I bought the car too.
Yeh I'll have to see. Came into the country over a year ago. If you're free tomorrow let us know, can come have a look :(
Yeh I'll have to see. Came into the country over a year ago. If you're free tomorrow let us know, can come have a look :)
What time you meeting up with him? Carindale's not that far and I'll need to drive a bit. Only clocked 50km for the past week and probably even lesser in the next couple of months!
Hahaha lame. I'll text you the time tomorrw dude...don't know atm.
First day back at training.
Didn't realise that a month off would make me so unfit.
And I jiggled in places I have never jiggled before.
117kg ftmfw!!!!!
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
