Nope :P I 'was' going for the nistune but now I'm not sure if I'm going to keep my car or not. Nistune being a cheap and very effective option...
Ask any mechanical engineer and they'll tell you if you want max power, forget about it being economical....
But I'm an Electrical Engineer... its about optimising and being efficient!
update:
car didnt make it out my driveway due to epic low
:bunny:
yes this means it is running strong :huh:
it's not that bad of a driveway :P ... how much stupid sauce was on the low burger?
*edit* and congrats on katie being up and about again :D *high five*
Edited by Isola
I didn't think there was a particularly good option for nistunes on 25s?
Either having to use a 20 ECU and lose VCT, or doing some sort of dodgy on a Z32 ecu?
You can't trust them though, they're always drunk.
Yeah the best option is using the z32 and keep vct. Its a pretty simple change over, no dodgy shit :P z32 ecu's are pretty cheap too and I spose you can get a lil money back selling your manual 33 ecu to someone doing a conversion...
Def agree with the drunk comment. Old uni mates are absolute pissheads....I envy them :bunny:
Nah man hes sayin when you start to chase power you throw fuel economy out the window
I'm a computer systems engineer... its about... um... getting the most amount of pay for the least work? :bunny:
Maybe he needs to learn how to leb-spec it more?
*edit* and congrats on katie being up and about again :huh: *high five*
+1. But its Katey :D
update:
:bunny:
yes this means it is running strong :D
I'll repeat what I said before.....SICK AS AIDS, breh. Chuck some planks of wood across your driveway :huh:
Exactly! This guy gets what I mean :P
Yeah the best option is using the z32 and keep vct. Its a pretty simple change over, no dodgy shit :bunny: z32 ecu's are pretty cheap too and I spose you can get a lil money back selling your manual 33 ecu to someone doing a conversion...
Coolies. I guess the only real downside then is you're still stuck with one of them dodgy AFM things :huh:
that's the best you could do for Damian's page?
:P
LOL
http://www.boostcruising.com/forums/index....t&id=956919
hectik uleh....
12 grand 380hp at 19psi,
can these things even handle that sort of power or is just wheelspin when u put ur foot down ?
300kms to a tank FTW :bunny:
450kms!!!
And even if I give it a bit every now and then, I'll still get 400kms. Anyway more accurate way to measure is 14L/100km
Nice! I was born in Mackay.
Whats out there? A mine or something?
They way I read it is that he was driving it up hills and leaving it in high gear (ie 4th or 5th) and then as it loaded up up the hill it started to struggle, so he held the clutch in instead of changing down a gear :P
Yea. We're building a new Coal Preparation Plant. I'll be there at least till end of May and probably go back again when I'm back from holiday until end of September when commissioning finishes.
Oh. I dont really read everything. Maybe thats why John gave me the "he's at it again". Hahaha I merely looked at the riding and slope. The first thing that came to my mind is taking off whilst on the slope.
hectik uleh....
Adam, I am serious. I'm going to punch you in the vaginee when I see you next for posting that on a skylines forum.... LOL
450kms!!!
You wish bish :P
Edited by yaface
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
