ha ha nice. i always get accused of 'driving silly' by my nieces even when im not
Yeah he's the opposite hey, hes only 4 an he loves boost already. Although I think if I did boost it properly he prob leave a small deposit on the seat :ermm:
I never get spotted either.
But I never drive my car, lol.
Take me to ice cream
I wouldnt be allowed to drive the Sil80 in your suburb, i would have to leave it at the boundary and borrow an A class merc to come in and get you
I'll drive the smart car to you :ermm:
I would Martin....i would
<3
LOL
So I been looking into possibilities of registering a C210, The "Special Interest Vehicle" registration (aka 30+ years old) would be sweet, except that it seems "Driving to a race track" does not come under any of the things you are allowed to drive on the road for :ermm:
i cant beleive you drive a smart car
oh and i also cant beleive what a mess C-Red made of your old silvia
<3
LOL
im sure you could lie about where you are really going
Anyone have updated photos?
The smart car makes me feel like a man
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
