On a serious note, my car got taken back today to get the front bar repaired properly....for the 3rd time. If anyone is free next week, pm me as we may have ourselves a good ol fashioned gathering with pitchforks and torches to put some panel repairers back in line
eeeps!
.9 bar makes me sad in the pants
Lol, be happy with what you got. I'm only running 12psi as of last friday....was 7 before :banana: ....think i might go jump now
Yeah, divide by zero always awesome.
Currently on hold with tpg. Awesome.
Good luck with that dude. Worse call centre ever.... You'll wait 30mins...sometimes get hung up on when you finally get through and sometimes even when you call through it cuts out straight away cos they can't take any calls in the que even....lame
TPG has some of the best deals, but i have to admit the crappiest customer service department ever, my housemate called them the day he was leavin to get our internet disconected, and they put us on hold for 45 mins, everytime we had to call them we were put on hold for atleast 20 mins
but theyr new plans are very good in terms of what you get for what you pay,
im gona go with the adsl2+ 120GB (60+60) plan once i move in to the new place, its shaped to 512K which is way better than my previous plan which was 64K, even google would take time to load at that speed lol
response and fuel economy over powa will be tuned at 0.9 bar,
EPIC EPIC EPIC EPIC EPIC EPIC EPIC EPIC FAIL
as does fuel economy on a gtr
+ 1
Save yourself the trouble and buy an Excel with a loud exhaust. Then the GTR can go to a nice loving home and be driven like she deserves.
Chalk has mad food! I'll never go there for a drink though. I'd need to remove my shoes, lose some teeth and fk my sister to fit in with the crowd there on a fri/sat night
I've seen the kind of people that go there. They'll never be getting my business.
Why wouldn't it? Does google have some weird load time exclusions, or exceptions?
Google always took time to load on dial up at 56K so I imagine 64K would be almost the same... Images and text... it's gonna take a second or two to load...
:banana:
lol everyone wants different things out of thier cars,my cars street driven and response and fuel economy is more important to me then having 250kw is, il tune it the way i want since i am forking out so much on it, with stock turbos im quite happy with 0.9 bar of boost.
afternoon
i see another day of solid whoring in here. to save me reading all the crap, did I miss much?
well, I just read through it all and posted to catch up... So I can safely say no.
From now on I'm going to call you Brandon 2.0
in all seriousness trying to save money on fuel and other assorted things and having a GTR is a bit like wanking with sandpaper it can be done but it isnt the right way and the end result wont be as enjoyable as it should have been
This is true unless you're german, in which case this is considered to be normal and sexually stimulating.....
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
