On a serious note, my car got taken back today to get the front bar repaired properly....for the 3rd time. If anyone is free next week, pm me as we may have ourselves a good ol fashioned gathering with pitchforks and torches to put some panel repairers back in line
eeeps!
.9 bar makes me sad in the pants
Lol, be happy with what you got. I'm only running 12psi as of last friday....was 7 before :banana: ....think i might go jump now
Yeah, divide by zero always awesome.
Currently on hold with tpg. Awesome.
Good luck with that dude. Worse call centre ever.... You'll wait 30mins...sometimes get hung up on when you finally get through and sometimes even when you call through it cuts out straight away cos they can't take any calls in the que even....lame
TPG has some of the best deals, but i have to admit the crappiest customer service department ever, my housemate called them the day he was leavin to get our internet disconected, and they put us on hold for 45 mins, everytime we had to call them we were put on hold for atleast 20 mins
but theyr new plans are very good in terms of what you get for what you pay,
im gona go with the adsl2+ 120GB (60+60) plan once i move in to the new place, its shaped to 512K which is way better than my previous plan which was 64K, even google would take time to load at that speed lol
response and fuel economy over powa will be tuned at 0.9 bar,
EPIC EPIC EPIC EPIC EPIC EPIC EPIC EPIC FAIL
as does fuel economy on a gtr
+ 1
Save yourself the trouble and buy an Excel with a loud exhaust. Then the GTR can go to a nice loving home and be driven like she deserves.
Chalk has mad food! I'll never go there for a drink though. I'd need to remove my shoes, lose some teeth and fk my sister to fit in with the crowd there on a fri/sat night
I've seen the kind of people that go there. They'll never be getting my business.
Why wouldn't it? Does google have some weird load time exclusions, or exceptions?
Google always took time to load on dial up at 56K so I imagine 64K would be almost the same... Images and text... it's gonna take a second or two to load...
:banana:
lol everyone wants different things out of thier cars,my cars street driven and response and fuel economy is more important to me then having 250kw is, il tune it the way i want since i am forking out so much on it, with stock turbos im quite happy with 0.9 bar of boost.
afternoon
i see another day of solid whoring in here. to save me reading all the crap, did I miss much?
well, I just read through it all and posted to catch up... So I can safely say no.
From now on I'm going to call you Brandon 2.0
in all seriousness trying to save money on fuel and other assorted things and having a GTR is a bit like wanking with sandpaper it can be done but it isnt the right way and the end result wont be as enjoyable as it should have been
This is true unless you're german, in which case this is considered to be normal and sexually stimulating.....
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
