rb26/30 - supercharged
you sure? the fact that the intake is where it is and the first pipe to the cooler looks a lot like a turbo set up to me
yeeeh im sure :thumbsup:
nice bro, just got word from Dan that dyno will be doen tomorrow so by monday i should definately have the car back, mayb even tomorrow if dyno can be finished early, gearbox feels smoooooth after Dan did a test drive hehe :thumbsup:,
u better be out next thursday bro, n since its next week you might even have some time to come over and help with the coilovers :D
Ok well... I"m about to head out once my mate finishes work, probably go past Harrys on the way to baskins... anyone keen? Jase you're northside yeah?
My bad. I'll make sure the next one is cheaper to reply to.
and how is getting things cheaper a bad thing? good to see you got your 5grand worth :thumbsup: lawl.
why don't you quote up your whats your wrong list again, or will it take up another page.?
and to think i work hard and had to help pay for it. and before you think your all cool and start saying shutup man your cars a roller, yes that may be so but even with the motor out its still more reliable then yours will be.
well thanks boys for a sweet night... Wicked cruise. Cant wait to get a good look at those videos my mate took!
As a follow up, I'm hoping to come out tonight for a spin... Harry's and then BNR chapel hill is it? Coming from the northside first, if anyone wants to meet up
Good to see you again :blink:
and how is getting things cheaper a bad thing? good to see you got your 5grand worth :) lawl.
If you were paying attention to the conversation in the first place instead of fapping over ugly ass cars you'd have noticed me say I *did* get my 5 grands worth, and that was the problem, that I should have held out for something better :blink:
awd isn't working... :bunny:
and no air con
and rooted immobiliser that I got ripped off for and it's not even installed properly
and tyres are 20 years old and dangerous as fuck
and rear rims are warped
and afm lasted 4 weeks
and reverse switch rooted
and no air con
There you go, Princess :rofl2: I even quoted it up twice to see if it would "take up another page" but I guess if it didn't take up a page to start with, it can hardly take up *another* page :D
You know the one thing I *didn't* do though. Was blame someone else for it (with the exception of the immobiliser because I think the guy may have been on blow). Some people could learn something from that.
I don't remember you paying my tax return or buying one of my guitars... and that was the only money that I used to pay for it all so far... So not quite sure how you helped me pay for it. Would that have even been possible? Do you even part with money?
and before you think your all cool and start saying "shutup man your cars a roller", yes that may be so but even with the motor out its still more reliable then yours will be.
Got your education for a steal too huh? :(
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
