At least you can play on the net!
Do you know how hard it is to look at pron with this damn filter they have here ?
Work colleagues ? There's nobody here but me.
Bring on the zombiesecks now
smashing day today.
on our way out for dinner, mate managed to rear end a car on the bridge right near the spit, doing about 50kmg. spent an hour on the bridge exchanging details and waiting for tow trucks.
four cars hit all up. magical. left leg is numb as f**k. will post a photo or two later. can't be stuffed now
smashing day today.
mmmm high accident zone.
how'd he manage that one?
couple cars ahead, somebody slammed on their brakes. few people in front just made it, mate didn't.
wasn't speeding, or following too closely. just didn't react in time. car locked up and slid straight into it
left leg is numb from trying to air brake in the passenger seat....
at least everyone is ok!
I've had passenger seat braking syndrome a couple of times myself. Never to the point where my leg goes numb though!
Locking myself inside as though the zombie apocalypse is upon us.
damn.
there is a car cruise and general knowledge thing happening at the norman park bowls club. Should be fun. i'll email you the details if you like john. apparently its a ( cant think of the word ) start at the bowls club go to the first point answer a general knowledge question they give you a ticket and you go to the next one etc all the way back to the bowls club and whoever gets closest to the time ( not a race ) with the most points wins.
damn.
If there's one on another day count me in :laugh:
Just not on Australia Day.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
