Never got into dexter....... what's it about
Dexter is a serial killer who cleans up all the murderers that the police system can't process because of loopholes in the system (illegal search warrants, tainted evidence, technicalities etc). He works with the police department as a blood spatter analyst and uses his position to get the info on all his victims.
It's quite a good watch, well written, brilliantly cast and keeps you wanting more and more. I slammed through the first two seasons in two and a half nights. Had no sleep and was functioning solely on V and coffee at work, total autopilot.
Season 3 was a one nighter, and Season 4 I just did over the last few days as a couple had to be downloaded again. I was not a patient person while waiting for them to download a second time... there was quite a lot of "The chili cookoff is happening right now! and i'm missing it!" dancing going on.
Worth checking out at least the first season if you've got the time.
BRRRRRRIIIIIIGGGGGGGSSSSSSSNNNNNSSSSSSTTTTTTRRRRRRRRAAAAAAAAAATTTTTTTTTOOOOOONNN
NNNNNN!
FYP
BAHAHAHAHAAHAHAHAHAHA! Imma paint it in John Deere colours and put an SR20DET badge on it
Taken care of :banana:
Dexter...blah blah blah
Hell keen! Sounds like a good show
do it mang! this series is just... chilling :(
And then burn a copy for me!
FYP
lol
If only you really were joking :(
yer :(
morning bitches
morning, my serbo-croat brother
ATTN: Tristan
Dude, might have a spot for you to play tonight if you're keen. Grand Final, beer at stake.
Not 100% sure yet, but just giving you more than 3 hours notice in case you're available. Let me know :banana:
The dirty sl*t ALWAYS wants to haul a big load. When/Where/Why/How/Who?
Need to take a fridge from Stafford to Aspley.
And Tas made mention of a GTR bonnet I might be able to get - Not sure where that's coming from, but it would also be going to aspley
:banana:
$100 brand new on ebay.
second hand ones tend to break.. If your keen I'll get one spilt postage or something.
Thanks for the offer, but that was more to let her know there wasn't one. I decided I'm not going to bother sourcing vents until I fix the AC. unless I happen to see some for $20 that is.
Once I've got the AC working, I'll replace my center one (I broke it the other day... long story) and buy a passenger one. So if you're still after one then :banana:
I'm sure there's SOMEONE who'd go halves though. You could probably even do a group buy for them! Enough people seem to need them!
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
