Call them hoebags and go off. They won't take you seriously unless you make a complaint about the service. They'll do a line test and then get you to mess with your settings. What modem you using? Dlink by any chance??
Dlink G604T or something like that.
No, one carton of XXXX and one of carlton :)
You shouldn't filter the line that the adsl is on...
If you have a 'splitter' that has an input and 2 outputs (one that says 'phone' and one that says 'adsl' or 'modem') then that's ok, just make sure you use the adsl/modem one. But if its just a plain old filter (one input one output) f**k it off, it'll be filtering out most of your adsl bandwidth
Nah its a splitter thingymabob with the two outputs and it is plugged into the adsl one. Was thinking it could be shitty phone lines in the building as it's 20+ years old. But still going to call them today.
secret drift morning session this morning
Side on pics so I can see these f**king wheels ffs!
have decided my car needs more epic downforce.
which one will provide me with the best results?:
Roof spoiler is the only way to go tbh.
Dlink are cr*p :). But I think theres another issue at play here.
Goodo.
Try going to http://www.speedtest.net/ to test your speed. Then see if you can find in your modem the line attenuation and noise, and synch speeds and post them up for me, along with the speed test results. (Make sure nothing else is smashing the internets when u run the speed test, ie torrents, etc).
They are teh sex
+1
well 260kb is about right for a 2mb line speed. But if you are that close to the exchange with ADSL2, you should be getting closer to 20mb line speed and 2000kb download.
Wots ur address (PM me if you like)
2930 Gold Coast Highway.
Yeah, you should really be getting 10x the speed that you are.
According to TPG maps:
Line of sight distance: 231m. Possible cable distance: 393m.
So basically, you are next door to it :P
i got this apparently its average
Yeah thats about what I was getting at St lucia, hope to get a lot more now because I'm closer to the exhange (although not as close as colin, about 600m line of site for me, 1-1.2km cable distance)
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
