Call them hoebags and go off. They won't take you seriously unless you make a complaint about the service. They'll do a line test and then get you to mess with your settings. What modem you using? Dlink by any chance??
Dlink G604T or something like that.
No, one carton of XXXX and one of carlton :)
You shouldn't filter the line that the adsl is on...
If you have a 'splitter' that has an input and 2 outputs (one that says 'phone' and one that says 'adsl' or 'modem') then that's ok, just make sure you use the adsl/modem one. But if its just a plain old filter (one input one output) f**k it off, it'll be filtering out most of your adsl bandwidth
Nah its a splitter thingymabob with the two outputs and it is plugged into the adsl one. Was thinking it could be shitty phone lines in the building as it's 20+ years old. But still going to call them today.
secret drift morning session this morning
Side on pics so I can see these f**king wheels ffs!
have decided my car needs more epic downforce.
which one will provide me with the best results?:
Roof spoiler is the only way to go tbh.
Dlink are cr*p :). But I think theres another issue at play here.
Goodo.
Try going to http://www.speedtest.net/ to test your speed. Then see if you can find in your modem the line attenuation and noise, and synch speeds and post them up for me, along with the speed test results. (Make sure nothing else is smashing the internets when u run the speed test, ie torrents, etc).
They are teh sex
+1
well 260kb is about right for a 2mb line speed. But if you are that close to the exchange with ADSL2, you should be getting closer to 20mb line speed and 2000kb download.
Wots ur address (PM me if you like)
2930 Gold Coast Highway.
Yeah, you should really be getting 10x the speed that you are.
According to TPG maps:
Line of sight distance: 231m. Possible cable distance: 393m.
So basically, you are next door to it :P
i got this apparently its average
Yeah thats about what I was getting at St lucia, hope to get a lot more now because I'm closer to the exhange (although not as close as colin, about 600m line of site for me, 1-1.2km cable distance)
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
