Call them hoebags and go off. They won't take you seriously unless you make a complaint about the service. They'll do a line test and then get you to mess with your settings. What modem you using? Dlink by any chance??
Dlink G604T or something like that.
No, one carton of XXXX and one of carlton :)
You shouldn't filter the line that the adsl is on...
If you have a 'splitter' that has an input and 2 outputs (one that says 'phone' and one that says 'adsl' or 'modem') then that's ok, just make sure you use the adsl/modem one. But if its just a plain old filter (one input one output) f**k it off, it'll be filtering out most of your adsl bandwidth
Nah its a splitter thingymabob with the two outputs and it is plugged into the adsl one. Was thinking it could be shitty phone lines in the building as it's 20+ years old. But still going to call them today.
secret drift morning session this morning
Side on pics so I can see these f**king wheels ffs!
have decided my car needs more epic downforce.
which one will provide me with the best results?:
Roof spoiler is the only way to go tbh.
Dlink are cr*p :). But I think theres another issue at play here.
Goodo.
Try going to http://www.speedtest.net/ to test your speed. Then see if you can find in your modem the line attenuation and noise, and synch speeds and post them up for me, along with the speed test results. (Make sure nothing else is smashing the internets when u run the speed test, ie torrents, etc).
They are teh sex
+1
well 260kb is about right for a 2mb line speed. But if you are that close to the exchange with ADSL2, you should be getting closer to 20mb line speed and 2000kb download.
Wots ur address (PM me if you like)
2930 Gold Coast Highway.
Yeah, you should really be getting 10x the speed that you are.
According to TPG maps:
Line of sight distance: 231m. Possible cable distance: 393m.
So basically, you are next door to it :P
i got this apparently its average
Yeah thats about what I was getting at St lucia, hope to get a lot more now because I'm closer to the exhange (although not as close as colin, about 600m line of site for me, 1-1.2km cable distance)
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
