Check out this email I just received from an engineer at work . . .
He says
"Sorry but I just realised that the last design I sent you still has the cornered corners on it. This .arch is called exactly the same but has the rounded edges, which is what we want"
I say
"Cornered Corners? As opposed to un-cornered corners right ?"
He says
"have a look and you will see what I mean. cornered corners as opposed to rounded corners.
f*kin knew someone would be a smartass when I wrote that... f*kin knew it would be you too Dan... can't help yourself... can't believe I wrote it anyway"
I say
"I think you mean chamfered corners"
He says
"Chamfered is what i will say next time.
Thank you for the destructive criticism Dan. Always there for me.
I'll just go knock myself out then."
Chillin at the train station with my abo homies yo. Keepin it real.
Lol, hope you're packing man.... I wanted to actually come tonight. I went over to pick my car up, assuming the front bar and some other things will be fixed and its fkn worse than before.... Fkn repairers....
weak moistcoils weak!
Oh you know exactly what to say to make a girl blush!! :blush:
How come you're not out there???
Don't drink all their goon now.
@John thanks for the lift.
( note to self don't open beers straight after epic mountain run style driving )
@Tas thanks for looking at my car really appreciate it
@Skins stop typing and drink the damn beer
You ragging on me? MF/
NP!
took a quick pic for u before i left work!
I like your steering wheel looks baller!
Edited by Redsuns88
NP!
Dry ice to get the deadner out ? Pfffttt thats the gay way. Fire is the way of the future.
No worries man, anytime :D
lol we already discussed that when you were getting out of the car! Did you forget on the epic walk back to your house from where I dropped you off? :)
But the walk was so long back to my place I forgot.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
