fag
sif fag. Recaro have been top dawg for years.
oh.. brides are sooo BALLLEERRRR
give me a bride lowmax.. anyway :)
:ermm: its raining.. start up my hachi... 1000hp yo!
Liquid hp awesome.
lol recaro pfftf...
would rather use a milk create with cardboard back rests
You don't count you drive an 86.
sparco ftw
AAANDD
man havnt u seen initial D? 86s smoke 32gtrs! and if its anime then its real
with the amount of rain we getting in stafford now.. my choice of car is a R33
Good call. No rain on the godl coast :)
sparco ftw
AAANDD
Yeah but taz is more like Itsuki rather than Takumi so its ok.
your just upset after i posted that ranga child on a tricycle..
its ok.. ill just take my aggression out on your sister..
soon u will hear songs like
"terri and tas sitting in a tree.. b-a-n-g-i-n-g"
When you coming to visit biatch! :)
gota do a few more bits and pieces on the 180 first bro, hoping to have it tidied up by next weekend
just waiting on a few parts
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
