fag
sif fag. Recaro have been top dawg for years.
oh.. brides are sooo BALLLEERRRR
give me a bride lowmax.. anyway :)
:ermm: its raining.. start up my hachi... 1000hp yo!
Liquid hp awesome.
lol recaro pfftf...
would rather use a milk create with cardboard back rests
You don't count you drive an 86.
sparco ftw
AAANDD
man havnt u seen initial D? 86s smoke 32gtrs! and if its anime then its real
with the amount of rain we getting in stafford now.. my choice of car is a R33
Good call. No rain on the godl coast :)
sparco ftw
AAANDD
Yeah but taz is more like Itsuki rather than Takumi so its ok.
your just upset after i posted that ranga child on a tricycle..
its ok.. ill just take my aggression out on your sister..
soon u will hear songs like
"terri and tas sitting in a tree.. b-a-n-g-i-n-g"
When you coming to visit biatch! :)
gota do a few more bits and pieces on the 180 first bro, hoping to have it tidied up by next weekend
just waiting on a few parts
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
