Goodeth lucketh ?
Day off!!!!
Good luck John
Thanks guys!
He said "you seem like a nice young man" which means I can still lie effectively :banana::banana:
Other than that he seemed pretty keen because I live so close, and have my open manual licence. He has a couple of other guys to interview this week, but I got a good vibe :D
Thanks guys!
Good shit man
He said "you seem like a nice young man" which means I can still lie effectively :D:banana:
LOL
Other than that he seemed pretty keen because I live so close, and have my open manual licence. He has a couple of other guys to interview this week, but I got a good vibe :(
Sounds excellent, Good luck!
So what are you doing for the rest of the day ?
+1. Did you manage to get a day off of from hell training for the interview?
Nope, no day off. Just got here at 10 instead of 9 :banana:
Oh. Apparently the meaning of "learn" has changed. I was asked "what have you learnt so far today?" and I replied "nothing new" yet still had to provide an example of something that I've learnt... Usually when you learn something you are aquiring NEW knowledge. Not just rehashing... but whatever... this is the same person who pronouces "operator" as "operations" :(
Typical... the point in time when I get to use the intertrons and all you bastards are off at lunch or something :(
Hahah
Im here . . . having lunch at my desk . . . again :banana:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
