for today and the rest of the week i am the workshop controller!
this is all
What type of workshop ?
Place that makes beer ? :P
Place that teach strippers how to dance ? :P
get your angle on!!!!
Jason:
Mechanical workshop, luxury car, i seem to be the most senior mechanic, so with the normal controller away im it.
ALSO.............
Would like to take this moment to thank martin (smity42) for driving to my house, removing parts from my project car, then driving 30km in rubbish weather (heavy rain) so i could have working wipers, then staying while i fitted them (and failed a couple times) then following me home.
Cheers very much, i owe you
ALSO.............
He's probably still feeling guilty from taking all those photos of you napping at the cricket
nom nom nom :)
ALSO.............
martin you're a sex cadet, and a top mate
but i must say - sif need wipers :)
man up dan
nom nom nom :)
on a quick side note, just before i go to bed, nom nom apparently, in thai, means boobies
nom nom nom, would therefore be three boobies?
WOW! Enough posts to multi-quote! :)
dear nismoh, dan, martin, and anyone else who cares :)
<3 astro
Nice job! So no excuses left to not come out on thursday this week?
ALSO.............
You forgot to mention the fine piece of JB I abandoned in order to save your sorry a*se :)
Nah no problems dude :)
Not at all :P that was thoroughly deserved.
I'm pretty sure I still owe Dan a few hundred favours in the grand scheme of things though...
Haven't had to split a post for a while...
I know :P
and a top mate
I know :D
man up dan
Normally I'd agree, however on the trip over there it was f*cking pissing down, couldnt see 2 feet in front even with wipers. However by the time we actually got the wipers repaired and left the carpark, it was mostly gone :)
3 sets of boobies would be better...
P.S. Where is thread for German club meet hey? ;)
three boobies! :)
wow :)
You say that now, but I bet if you saw a chick with 3 boobies you wouldn't like. Its not natural...
For those who have a interest or for those who don't
At current there is
4500L/s of sewage leaving brisbane.
Pretty boring really.
Why is it leaving? What did you say?
That's how we do it. It's the easiest way.
Sounds like a good system tbh
this is all
Is that like the fat flamin mongrelroller?
dear nismoh, dan, martin, and anyone else who cares ;)
<3 astro
:) Good to see you're out sliding again. Gimme another 5 months :P and I'll be out there with the cop :)
ALSO.............
I feel the love
Shock horror!
+11ty Although I won't be there.
You forgot to mention the fine piece of JB I abandoned in order to save your sorry a*se :D
:) You are a better friend than most good sir
cbf multi quote so:
Here be internets!
I see skids! <3
'sif abandon JB :) Dan could have waited. He could have had another nap to pass the time!
3 boobs is too weird... I +1 with the 3 sets suggestion. But they need to be big sets. And attached to JB.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
