@ Colin - have you done any work on the GTR yet since it's been off the road?
Nop. Too hot n too lazy when ever I go home for the weekend. That and I've had no cash to chuck at it yet. Still got 20 weeks. So plenty of time yet lol.
I hate him so much
Cleaning it doesn't count :D
Where's my dirt ?
That's what she said
Mang
Mature age apprenticeship?
Where's my dirt?!
That's what she said.
Nah...your just not trying enough
Close though... here is a mickey mouse badge :D
and 2000
the end.
Cleaning counts mofo.
I'm out for tonight guys... picking up a girl or two and going to watch my mate dj in the valley :)
The Friend Zone. You are in it.
Morning Mr. Mandawai Udipingu
Morning Pom
Sup mang. What mangin today?
well i lie, i msgd dan as i figured you were with dan..
I'm still confused :ermm:
I'm sorry that dan dindn't respond to ur msg. Not sure why it's my fault but :)
*starts cutting*
yeah tgif I spose. Dunno what I'm gunna do for the weekend though....
Imma going to look at C210s, guns, etc
and mebbe move the workbench from the shed up into the garage
Hey all.... what's news?
No u.
*starts cutting*
C210s eh. What are you going to do with it? Restore? Epic conversion? Rust in backyard?
Yay ordered my new black shift & handbrake boots today :ermm: Finally can replace that horrible white crap thats on there.
Then all I need is my front mount and itl be ready for the HPI photo shoot :)
wow you fo-real?
nice work man!
Yeah whitey hooked it up for me :) Got a set of 17's wit shitty tyres off a mate too so I can bag it up for the shoot ! Cant wait :ermm:
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
