that sucks :( what's the budget?
there's this
orrrrr.... we know someone selling a Z31. It's an auto though, so it'll need some work done.
Hmmmm old skool supra with a 2JZ? has potential...
Z31s catch fire :)
you already own somthing old school :blink:
Does that mean you thing my 31 is cool? <3
Older school. Something I can run a dirty carbie 6 banger in
ewww ginger :)
+1
unless it's Molly... I'd eat THAT kind of ginger ;)
A mention of Molly and no picture? What is the world coming to? But +11ty.
Thread save:
Bit laggy here but it could be the filter... damn you filter!!!
F*ck filters
I thought thats what your 31 was ?
So you think my 31 is cool as well :O I love you guys
Damn someone at work wants me to work :( What do they think this is ? Work ?
That's just not cricket!
and all you do is play with water/poo
Oh SNAP
I just watched The Taking Of Pelham 123 (which I bought yesterday). So that makes my weekend infinitely better than everyone's* :)
*unless someone else was watching it too in which case we're even...
Afternoon all.
Total amount of sleep since friday: 2.25 hrs
Total amount of fun had: 11tybazillionnnnn
The number of beers is also waaaaaay up there lol..... Mr Skins you thoroughly confused my friends on facebook lol
Also..... Morgan.......................... :):)
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
