http://www.boostcruising.com/forums/index....howtopic=524548
This is f**ked. Nothing against cheaper labour with higher production but QA standard should be maintained regardly of any industry you're in.
HA! uni damn bludgers, enjoy the train....
I agree with john, the top will be off by that stage, and it will be her job to clean up
FFFFFFFFUUUUUUU. god damn train can suck my bawls.
well... the aquisition of money = win. But the fact that you had to fag out and go to a casino for it = massive fail
so all you really did was gay up a totally awesome movie.
what are you spending this newfound money on by the way? lessons in not being gay? because if you're not *shakes fist*... although I will also accept it being spent on either car... or my car :)
Casinos are one a mans greatest inventions in no other place can you see so many peoples hopes and dreams come crashing down around their ears. The olympic games come close.
not sure. doesn't say on her profile.
who cares?
has to be 16/17? Senior in high school right?
tl;dr cliffs?
Morning Mangs :)
What about me ? Where did you get this picture from ? Nice
Sorry. Faceparty
Mr Coils. Confusion is the way of the future :)
I like it
Side note work is gay.
+11ty
Why... that would be facebook, dear chap!
Yes, and LOL at you deciding to add her as a friend after seeing that pic
Oh I see. Well played dear fellow. *adjusts pipe*
I tip my hat to you, gents
crazy half-cast bastard... we discussed this on thursday. speak english!
HARRO! ENGRISH PREASE!!!
Not as nice as the pic that's on here though... Wonder how old she is ...
Old enough
who cares?
+1
That's precisely what I'd give her :)
LOL
Edited by Smity42
Contrary to popular belief... I am only human after all :D
I would dig through and find a quote where you said you deleted all baskins girls and weren't going to add any more, but I cbf :thumbsup:
Dan and I were thinking we should get a life-sized cardboard cutout made of that pic and stick it in the passenger seat, and park right in front of the store on thursday
PURE WIN!
dooo it
actually I said I CBF adding any more, not that I wasn't going to :D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
