found something to get instead of the C210: http://cgi.ebay.com.au/r32-4-door-drift-pr...=item27af6efba8
saw this the other day and it just made me lol. I spent 5 mins trying to figure out why and then realised it was an effort in futility.
Sorry Andy, it couldn't be helped :ermm:
AND LOOK WHO ADDED COLIN AS A FRIEND ON FACEPARTY: http://www.facebook.com/profile.php?id=100000697367718
I'm really suprised it took you guys to find that out she made that like 2 or 3 weeks ago. But it was inevitable.
Bought my new EEE PC today. $475 for one of the new ones with Intel Atom N450 processor, 2gb ram, 250gb hd, windows 7, 6 cell battery n everything. I thought it was a good deal :( Now I can watch porn on the train :)
was pretty good. stayed at home mostly and watched movies 'n' junk.
of course it does - it's the end of the work week :)
any good movies ? I saw that lovely bones movie... kinda a chick flick
Evening Mr. Coils
Even gents. Jason I sent you a link on FB to clear up today's confusion lol..... this confusion is getting to be a 'thing'.
I'm leaning towards the nismo shocks..... I wonder if putting my king springs on them would work ok. I'm unsure what springs he has on them now.... hmm...
You sent me a link ? I'll have to go and confuse the heck out of it
Be right back
any good movies ?
Pelham
Final Destination (3D version)
And watched a lot of Simpsons.
Thinking about watching The Green Mile... but that's on the other side of the room. And I have 600GB of crap in front of me that I can watch.
Pelham
Latest season of simpsons ? If so can i "borrow" it ?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
