what tha eff?
google it. Get in a big blow up ball and roll down a hill. Terri asked me if I wanted to go and to ask "The Skyline Boys" if they wanted to come. So anyone in?
If by 31 ute you meant, say something like an X5?
Sure
I can paint a big "X5" on the bonnet if you like?
Nah, I tried phoning option 1 but didn't get a reply. Ended up taking it to Bosman Tyres. Roy noticed that the castor rod bushes were cracked, so theres another thing for the to-do list!
Ahh yep, I've dealt with Roy before too, he's a champion
Afternoon chaps...... nothing much to say
GTFO then :ninja:
i'm in if t!ts out
...do you have to walk up the hill? :ninja:
Hey bro got the stickers today . . . Thnx heaps :ninja: Ruv you Rong time :P
f**k dude thats quick - i only dropped them in the letter box yesterday!
wooo hoooooo :ninja:
X5? but why? M3 ftmfw...
E30 M3 is too old for work, I cant afford an E46 M3 out right and I refuse to get a loan and I don't think i'd be 100% happy with an E36 M3 (3.2 6spd spec).
I want an SUV, Range Rovers are too much for me to buy out right
X6??
Whats that? If I'm in Brisbane I'm in!
I'll come along to watch you all make fools of yourselves in the zorb..... and maybe rip some skids in the big field you go rolling down :)
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
