hehe remember the time on msn when both our sarcasm detectors were broken?
like this one time at band camp :)
Got any idea's - must be euro only
Audi S4?
You just made a friend
You just lost one
That.looks.f**king.sick.nuts. I am f**king going to apply!! Once I find out more...
Non zorbing fags...
new bmw's are fail josh, anything in this new style they are heading is crap, pure boring and cheap feel inside.
Honestly i would prefer a E46 M3 over the latest E92 M3 (or is it E90, meh too long since i worked there)
The X5 is a fail, and the X6 should never have been thought of, X3 is even worse then both combined. Range Rovers are for drug dealers.
I agree with colin, look towards Audi's, also i happen to work at this said dealership and can introduce you to salesmen who will do you a very nice price..........
And john, send me said pics of chick licking herself... i am interested in this.. :)
Ok I'm really really lost with all the talk of girls and licking themselves and what-not..... can someone PLEASE just send me some damn photos?? :)
Haha, thanks John, top vid
No worries
win video is win!
It sure is :)
said picture is also relevant to my interests...
I also sent it you ranga-boi!
I don't has your number - sendy no worky
meh, cod mw2 for a few more minutes then bed time.
boss is away for two weeks, so am thinking 10am start tomorrow, and finishing around 12pm. then it's bourbon a clock.
ps. if anybody knows where i can get an a pillar doube gauge holder thingy mcjig for a r32, pm me.
mine has a crack in it so is due for a replacement.
He doesn't say much
I like what he says though
Bourbon
Win :devil:
win video is win!
These statements echo my own thoughts on the subject. :devil:
Most of the sponsors on here would carry them. Check the business section or you could try ebay?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
