Rule 1 - Martin is always right.
Rule 2 - If Martin is wrong refer to Rule 1.
:D
sig'd
unless u own a KFC somewhere i think they're kind of lame. But if u like em go for it.
LOL. +1
Hmmm well I do like KFC but I defs don't own one... I kinda like the idea of passing someone..... and being all like ZINNNNNNNNGGGGGGG
need pics of your car with new stickers :D
Yeah I havnt put em on yet cause every time I went outside it was raining :D
Will do it for sure when I get back next week
OMG A GABNR!
from memory its a mythical japanese dragon like creature with 8 dicks, but only 15nuts or something
it eats godzillas for breakfast
micheal knows more about it than i
This is true, Ive seen one
Havnt u got any on your car yet ?
nooope shes totally sticker free
have a few waiting, waiting for better weather and for when shes driving again :D
:D
sig'd
LOL. +1
That reminds me I need a sig...
I can imagine you doing that as well lol.
Sup boys :D
Mang *tips hat*
My suggestion:
Lol good call.
Martin/DanB/Anyone else who might have an idea. What other options do I have for brakes on the 31 if I want to use the S13 suspension? Will 32 hubs n shit bolt up to S13 suspension or am I way off. Such a pain in the arse trying to get hubs n knuckles off someone.
dear colin
<3 astro
<3 long time. Funny thing is as soon as I posted that up I found somebody selling them on SD as well lmao. How much you reckon is fair for all that shit? Was thinking like $250-$300ish? They're only shitty 4 stud stuff anyways lol
umm i have no clue man, but as you say they are 4 stud, no one really wants them - defs an item to negotiate on
whats the SD dude want?
no idea. His stuff is still on the car. He is doing a 5 stud conversion so will sell them once they're off. I've seen some sold on SD for like $150-$250. I put an offer on boost lol. Should of made it less i think.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
