rear end swings out
i noticed this mornin driving to work in the rain when i took corners the back end feels very light and wants to kick out on every corner or turn i take when i shake the steering wheel going straight the back end is all over the show and i spun out takin a corner goin to work i took it at 20 slowed down into first and went to go up the hill but it just slid out on the turn when i put my foot on acelorator it doesnt feel like wheen spin more like wheels lock ive looked at tyres there about half tred but worn and cracked from age
mate told me repllace all rear suspension and should fix it?
Epic lulz
Hahaha what the f*ck ? Is that for real ?
Yes. Copy pasta some responses for fun. OP posts in bold:
first, you need to learn to drive
after that, replace all your trailing arm bushes
i do know how to drive
I'd start with replacing those tyres, old, hard tyres are probably worse than bald soft ones.
other than that, I'd say adjust your driving style, will probably have alot to do with it regardless of what you post on here.
if you looped it then clearly you don't
but what would i know
Old hard cracked tyres and wet road, bad mix.
becoming a pro drift! :laugh: :laugh:
haha my car doesnt have enough power to wheel spin
thanks mate oh i think it was a mistake by me yesterday i took same corner today and nothin happened but the back end does need attention when i take corners it feels like it moves more then it should so will do bushes shocks and tyres overtime and see how it goes was meant to be a weekend thing but now ive gotta find the cash due to the weather works slow so funds go else where just takin corners slow
your right foot makes the back kick out, your car isn't KIT, it does what you tell it to.
so whos in for tonight?
I'm in for tonight. Dunno how I'm gunna get there yet. One of my mates might drop us off. I'll let you guys know if I need a lift :D
becoming a pro drift! :D:huh:
OMFG wat a spooger
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
