rear end swings out
i noticed this mornin driving to work in the rain when i took corners the back end feels very light and wants to kick out on every corner or turn i take when i shake the steering wheel going straight the back end is all over the show and i spun out takin a corner goin to work i took it at 20 slowed down into first and went to go up the hill but it just slid out on the turn when i put my foot on acelorator it doesnt feel like wheen spin more like wheels lock ive looked at tyres there about half tred but worn and cracked from age
mate told me repllace all rear suspension and should fix it?
Epic lulz
Hahaha what the f*ck ? Is that for real ?
Yes. Copy pasta some responses for fun. OP posts in bold:
first, you need to learn to drive
after that, replace all your trailing arm bushes
i do know how to drive
I'd start with replacing those tyres, old, hard tyres are probably worse than bald soft ones.
other than that, I'd say adjust your driving style, will probably have alot to do with it regardless of what you post on here.
if you looped it then clearly you don't
but what would i know
Old hard cracked tyres and wet road, bad mix.
becoming a pro drift! :laugh: :laugh:
haha my car doesnt have enough power to wheel spin
thanks mate oh i think it was a mistake by me yesterday i took same corner today and nothin happened but the back end does need attention when i take corners it feels like it moves more then it should so will do bushes shocks and tyres overtime and see how it goes was meant to be a weekend thing but now ive gotta find the cash due to the weather works slow so funds go else where just takin corners slow
your right foot makes the back kick out, your car isn't KIT, it does what you tell it to.
so whos in for tonight?
I'm in for tonight. Dunno how I'm gunna get there yet. One of my mates might drop us off. I'll let you guys know if I need a lift :D
becoming a pro drift! :D:huh:
OMFG wat a spooger
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
