my lunch was good, aside from the fact that a work mate spilled 2 schooners in my lap....but i got to come home so i guess that was win after all!
Spilling beers on your mate . . . 1 star
ohk ohk well so we dont match ill go for shallow ocean blue turtle neck with a pair of arctic ice shelf pants
when we are out i can get a 6pm winters sky navy scarf to compliment turtle neck
<3 Dudeman
THAT IS SO SIG'D
I just saw what appeared to be a very very worked NA 180 on Maundrell Tce/Hamilton Rd. White one, with rims like Josh's but not as much dish. Tristan, you probably would have jizzed buckets.
jizzed buckets . . . . lolz
So, big thanks to Andy for pointing me to that thread. It's working now, and if it stops working again, at least I know how to fix it :)
good stuff!
i want jackpot noddles however cbf walking into the city, and i only have another 45minutes until next class ugggh
i was at jackpot in the city at 1pm having lunch. should have legged it over, could have shouted you lunch on my work account ;)
and on a side note, i finally got some injectors.
sard 550's arriving next week sometime, so just a matter of getting a z32 afm, and then installing the rest of the go fast bits ;)
sard 550's arriving next week sometime, so just a matter of getting a z32 afm, and then installing the rest of the go fast bits :)
fuck yeah, Miso. ;)
Fuck yeah.
f**k MAN!
ugh that would have been awesome
oh yeeeh - ive been waiting for this for over a year, at least
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
