twas sooo funny i had my arm out the window to take it hahahahahha
not stealth at all :(
it also had a huge cannon with the tip painted that cool titanium blue colour :down:
the lotus cup always good driving!
+11ty. Been watching a lot of the BTCC as well.
what's mang'n mang
Mang I just got manged by this mangin manglette. It's manged up my mang so far. Mang...
oh hai there!
love the vid
colin you are a god when it comes to top gear
i <3 gt wings - however saw a magna today with one - took pics as i was driving - will post soon!
lol I would do the same if I had a fagna.
lol, I copped a face-full of cricket ball tonight (again)
few stitches across the nose, no biggy
protip: don't go to the private emergency room, it is epic expensive
Did they bring da ambalamps?
wiat what? martin u got hit :down:
I dunno if I should laugh or not. Last time I did that karma gave me the ass ramming of a lifetime. Well maybe not but something bad happened :(
Dear Jason,
<3
Where was my invite?
No, no ambalamps for me :down:
I decided however that I deserve a day off work :down:
Ha ha ha in their natural environment. Looks kinda like a nature shot... where's the voice over? :(
I'll see if I can organise another one if you like. Have to ask how many he can take through at a time without too much trouble.
No, no ambalamps for me :(
Win?
Ha ha ha in their natural environment. Looks kinda like a nature shot... where's the voice over? :down:
*David Attenborough voice* As we can see here the nissan skyline in its natural environment. The younger male R33 is protecting its nest and its mate. The R33 is mainly a water dwelling creature and often looks awkward and boatlike when it is on land...
Win?
Hahahaha
I can talk to my mate again and see if he can do another tour. Pics are one my fb Mr. Coils.
Still broken :) hurry up and fix it John
Did you go inside the dam wall and shiz? I love somerset its so old school
Sure did. All the way to the bottom of it. Think John has a pic of the walkway at the bottom.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
