Chicks love scars martin, just remove the stiches yourself at work tomorrow.....
Skins, put me down for a DAMBUSTER TOUR!!! im keen!
John:
The VG will fit in, has been done before on a 32, the only big problem will be a custom/modified sump to retain the 4WD system, from memory the VG30 is similar in electronics to the rb25's so wiring wise it won't be too much of a problem, Kev can make a plug and play loom up for cheap money!
Gearbox, the vg30 bellhouse bolts onto the rb25det box so if the gts-4 box is a same bolt pattern as that it will bolt straight up. VG is possible, will just be more expensive.
VQ's to retain the 4wd will need alot of work, custom bellhouse for one, if you want to drop the 4wd then buy a vq35 6 speed, only $2700 or so from option 1. VH's need custom bellhouse unless your a girly man and want an auto track car, which if thats the case, sell and buy a HSV.
Anythings possible, just cash involved, cheapest option and best bang for buck, RB25DET conversion with the 4WD system, swap sumps, modified wiring loom and away you go.
Or cheaper again? RB25 turbo on the 20, front mount and boost controller
John:
DAMBUSTER TOUR
FULL
More important note :
Morgan will not be attending B&R tomorrow
I repeat
That is all.
Sad, sad day
SOMERSET DAM TOUR ( update )
Maximum of 8 people at a time.
Date and time to be nutted out.
Let me know who's interested and we'll go from there
The end.
:P
Oooooooooohhhkkkkkk I'm with you now man. I'm in for a weekend depending on when obviously.... may or may not bring someone, depending on numbers, it's up to you completely dude.
hey guys,
names callum,
ive been on sau a while now but im not actually on it much, damn uni study lol
anywho just thought id put my hand up n say id be up for a cruise.
im located around the mt ommaney area if anyone knows that area.
cheers guys
hopefully some fun drives to come
hey guys,
names callum,
cheers guys
pfftf mt ommaney :blink:
tommorrow night at baskins n robins at indooroopilly along moggil road usual meet up @7.30 till late
he meant to say CHAPEL HILL. It's just past the Lexus dealership on Moggill Road. Get there early to secure a chair!!
hahaa i know where it is, i dont live under a rock.
mind u uni does kill all social life
righty dokie then! less info next time :blink:
technically that area is boarder line chappel hill/kenmore/indooroopilly
i like to choose the better of them and have a suburb where people cant really say it :down:
it's not border line jack and or shit. The official boundary for Indooroopilly finishes on the western corner of Rennies Rd. Just because your house is Indooroopilly doesn't mean shit ;) Moggill Rd moves south west at that point and crosses back through the border putting your street (from the first HOUSE) in Indooroopilly.
Don't argue directions with the ex cabbie bitch :P
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
