Farkn lol
I think that makes more sense that what you usually say.
Morning mangs.
I won't deny it.
Morning to you too *tips hat*
oi ravbat, i <3 you
<3
ps, guess waht song is on channel V right now?
il give you a hint...
SSHHAAWWWTTTYYYYSS LIKE A MELODY IN MY HEADDD
BEST
i <3 memories by david guetta/kid cudi
ALSO BEST, MORE BEST THAN PREVIOUS BEST, SO THEREFORE 'BEST'
Ugh so not looking forward to this, i hate going to court, If i was judge dread i wouldnt even need to go, my refusal documentation would be accompanied by a loaded gun for them to use on them selves to save me the trouble of coming round and administering my refusal in person!
4000 posts = best?
Its over 94000!
Do it the Chuck Norris way. Roundhouse kick to the face.
i dont get it..what happened?
Your doing it wrong.
I will have to go to court for work stuff AGAIN, Any time someone appeals a decision or is fined for compliance matters we always end up in court
Tas, do you realise you come across as a total douche in just about EVERY post you make on here?
However, I think in this case he's actually right boys:
The building '620' is where baskins is.
Good poasting. Further enforces Rules 1 & 2 :D
I thought that was me ? :D
How'd you get access to BCC stuff ? :laugh:
naaaahhhhh, you come across as a mad kent :D
On the internets...
Yes... the illusion is complete
How many internets do you need ? I only has three. :laugh:
Lol rightio lol i think ive lived in that house more then u been a cabby mate
What's that got to do with it?
Unless they change the boarders in last 3 years i do not believe what u say is true! :D
It's been the same for a very very long time
Actually, you just proved what I said. Here's a closer look at how that border line actually works:
As you can see - the border lane runs BESIDE the road, giving everything on that section of Moggill Rd a street address of Chapel Hill (including Baskins, represented here by a black dot). Everything behind the line is Indooroopilly. If it were on suburb on each side of the road, it would look like this instead:
Edited by Isola
I rest my case
Is your case tired? :D
I'm off to uni hurrah. SUPEER GREATOO TRAIN TIME!
But yeah Martin I thought you had to pay for access to those suburb maps? I tried looking for em but my googling skills were inadequate.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
