suck shit ranga, enjoy your half K walk :(
:P
im sure no body cares but i will be late.. still putting this head together for the drag car
Pics?
I will try to make it. If I do, it will be in the 32.
Sickness. I'm already here. Just chillin doing some trigonometry lmao
With skins u just need to tell him the assume the position and his on it like a fag in heat.. lol
oh hey Danb Skins got something to ask!!
:P
I'm not on msn because I'm at the pub... Sheesh
only fags blush lol colins just a ranga so it may look like his blushing but his a ranga.. lol
DAN!!!! i got something to ask mate.. see i got a mate called Gayson.. but lets call him binz for short..
Anyways cut to the chase... your missus for a sister mate?
personally i think its best to pm me the contact details just incase gayson aka binz see this!! :P :P
lol hahah fag skins fk i meant BInZ
lol haha jk im just shit stirring..
nah she got a sister mate?? lol hahahah i asked first!!! remember u called the one and u got to stick with it skins!! warm baths for u!
Edited by Redsuns88
Haha :P
Alright, I've sent out the texts to see if I can get a crew together for a drive :P
no crew? Bring the 34 next week? :D
Also - how much are you chasing for your M spec bar, and what does an M spec spoiler look like? Thanks ;)
personally i think its best to pm me the contact details just incase gayson aka binz see this!! :P;)
:P
You? Drinking? LIES!!
Was so :D
lowball club is not fun any more :P:
Thou shalt not post pro pedophilia images/videos, regardless of intention of a joke, or it being a popular internet meme.
Thou shalt not liken the Moderation Team to nazi germany. The Holocaust was a horrific part of the worlds history, the nazi's killed between 11-17million human beings in what can only be described as genocide. we are just a bunch of people who dedicate our spare time to the upkeep of this forum. respect that or find yourself unable to contribute.
Edited by Smity42
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
