Hi all..... so went camping fri + sat nights. Mates forester GT ran out of fuel out near kenilworth in pitch black at like 9pm fri night and none of us had reception. Took about 2 hours to get that sorted. We ended up sitting on the side of the road with him having a "few" beers while our other mates went and got some fuel hahahahahaha.
f**kin scary... we were basically in wolf creek lol
Edited by mosquitocoils
Shit day at lakeside today :)
Got stuck in a group with a bunch of sunday drivers, first session got about 2 half decent laps in, the rest were all stuck in traffic.
Second session I came through under the bridge too hot, did a 360, and then slid into the wall. I actually thought I'd managed to avoid the wall but just slid into it on the grass:
Pulled it all apart when I got home.
Guard. Could probably salvage it but not worth it, I'll get a new one:
Bumper reo got a bit bent but nothing that would stop it being used:
Filler panel also got a bit of damage but again, nothing to require replacing:
Headlight glass survived, a bit of paint to get off though:
All the mounts are cracked though. Hopefully I can get this fixed at a plastic welder or something. Don't want to have to buy another projector:
On the bright side, the body underneath it all looks straight:
So I'm probably just up for a guard, front bar skin, and some painting.
Andy, I might need to hit you up for you painter friend soon...
here's a video from session 1 of the couple of fast(ish) laps I got in:
at about the 35 second mark is my lakeside drifting :)
@Andy, does your mate do other panel work besides painting? I might need my front bar plastic welded and cleaned up before painting, and a couple of vents fitted, reckon he could do that?
marto looks awesome!
epic hand control while skidding :cool:
Boy's got skillz :P
ps next saturday we're finishing it :P
Haha, I may have to prioritize now. Its OK though, I'm sure Dan will help you out ;P
ps
LOL
at about the 35 second mark is my lakeside drifting :cool:
looks fun.
will have to make it to a few of the days later in the year.
Boy's got skillz :cool:
you're alrght
yeeh fair call, idk about dan though - hes a cronic "no msg/no phone call" dog
unless he wants to redeem himself?
Sucks about the acco, when you want to get it in let me know! Im pretty sure he doesnt plastic weld but can get it organised at a decent price
you're alrght
I think he just knows how shit S13s are to work on...
Cool, I'll hit you up once I've sourced some panels...
ahhh that sucks, Martin :(
At least it's not too bad though!
Could have been worse...
Morning slarts,
Messy weekend.
That is all.
Same, St Patricks parade celebrations at the Irish Club are f**king awesome, im going back on wednesday
sick
Epic main hall panorama
played kings with 3 decks of cards and a yard glass. All kinds of bad.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
