What you getting from there?
some steering rack bushes :)
You going tonight Jason? Or working? If you're going, wanna drive over together? I gotta give you back your socket and ratchet, and we should limiter bash a tunnel on the way there :D
rb20 <3 limiter
You going tonight Jason? Or working? If you're going, wanna drive over together? I gotta give you back your socket and ratchet, and we should limiter bash a tunnel on the way there :)
Am i going ? Yep :(
Sounds like a plan. In for the tunnel :D
Am i going ? Yep :)
Sweet - meet at your place? What time?
Damn I hate failing at life :(
awwww we still <3 you :)
Have you had chance to resize that gif yet ?
It's not about having a chance - I need my other computer with all my graphics programs on it. Don't has other computer here. It's buried under boxes of stuff at my Mum's house.
p.s. Why the f*ck are my posts going on top of the quote ? :(
Because you don't know where to put the cursor?
it's called "failing at life" :D
+1 :)
What needs to be done? Just resize a gif? If its not animated send it here I'll do it...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
