And on the second day God said unto John PUT THEM ON THE CAR BIATCH. And through God's fury John saw the light and all was well.
And on the third day God said "Silence the dirty ranga!"
and God saw that it was good.
and on the fourth day. God said "Needs more low". And John said unto God...
"Niggah please! You pay for it!"
Dear Martin,
here is my "blueprint" for my BOV shield that I was trying to explain.
As you can see, it lets more air through, but still not enough to totally let the valve open and release all the air before it goes back to the turbo, enough that it would probably avoid a full flutter though, and just do a flutter dump and make it a stuttering hiss instead of a sigh.
One day when I'm not lazy, and can steal Jason's tools again, I'll give it a go and tell you if it works.
Big <3s from your Advan Brother
im so f**king dnrunk omfgggg
i <3 SR and everyone who helped me put it back in for the 2nd timeee
omg this sceen is f**king ubrly as f**k
ps <3 marto an dan and dave ooomg
I has an angle grinder...
Gaids :D
+1
Just got home/ going to bed/ updated my sig poast!
I got home and thought about your sister, that UPdated my post :(
what about the beer and the chainsaws?
+1
Dear Martin,
Mine does not have that bevelled section or the second hole (from memory anyway). It's just flat, like the Left hand side of yours in that pic on both sides. Strange, maybe mine is actually a 32 item or something. Wouldn't surprise me, that sped Erin ripped me off on the motor I'm sure he wouldn't be averse to putting a few 32 bits on there...
<3 Brother
P.S. Thats now officially 2 cars that I think look good on advans :blink:
Marry me, you sexy beast
Edited by Smity42
Martin, if you need some one to fix your paint up let me know!
Thanks Mate, yeah I definitely will if I can't sort it out!
He should definitely repaint the filler panel for me: if I wanted paint with runs in it I could have done it myself!
The front bar might be more of an argument, since theres nothign really wrong with it other than being a very average job :(. Might need to get your mate to re-do it for me, I'm not going to hand over any more money to this guy.
cool not a worry
John those wheels are lookin good........ and yep needs more low now hahahaha = $$$ :(
Tristan you are a god <3
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
