name='Isola' date='28 Mar 2010, 02:22 AM' post='5153241']
there's no keener kind of keen!!
If only there was... it will always be the dream.
Avatar... fern gully
Same thing ? :O
For Tristan:
How to properly repair rust, something which whoever did the dodgy-ass job on your 180 should take note of (Note: not the job Dave did last weekend, that shit is legit. I am talking about whoever did the original abortion). Bought to you by Garage 31.
Step 1: Actually remove all the rust.
Step 2: Apply paint. For best results, this should be the same colour as the original paint and done by someone who knows what they are doing. But at the very least paint it with something, to prevent MORE rust.
Step 3: Profit.
Result:
Big thanks to Dan for coming and doing the major bits of painting last night!
After lunch, all the panels will be going back on. Then its a trip to the paint shop tomorrow to try and sort out the dodgy ones...
Edited by Smity42
YOU'RE a dodgy one....
For Tristan:
agreed - grinding back, and exposing the rust - and not treating it at all is a piss weak effort, much can be said about such questionable workmanship
however,
another thought for rust (not removal, but maybe containing?) is when u have a small amount of rust from where the paint cracked when u rolled your guards - simply cover it with some clear nail polish - and it will contain it, until u are ready to remove it and fix it correctly (usually done when car is re-sprayed)
i am going to do this once it stops raining and it is dry ;)
the job you've done in the pics looks quality mang!
ps, also ordered some epic headlights - hopefully ill actaully be able to see more than 10metres in front of me hahahha
That's what she said
however,
Yep, I've been busy fixing all the rust from guard rolling too. I sand the rust off, and then hit it with touch up paint.
But good call on the nail polish, that should stop it rusting at all if you apply it as soon as the paint starts to crack.
im going to dodge the f**k out of you
went zorbing today. was awesome fun. Started the gtr as well. want to drive so bad lol. Ill grab some pics of the new ESSSS AARRRR now.
Speaking of pics. Here is what Dan aka The Legend - did for me today:
Right:
Left:
Front:
Rear:
And not only that. He also got my A/C working!!!! ;)
I drove home with the windows up!!
Thanks heaps Dan! Awesome work :blush:
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
