What
The
F_ck
Woman set on fire during surgery
Happy John :D
Fire, solves everything.
fix it... making brain hurt
Fixed:
I say, old chaps, I do appear to be suffering some minor homosexual tendencies when posting on this fine forum. My browser of choice is the fabled Internet Explorer but alas, when I submit a post it appears not once, but twice! It's just not cricket.
Edited by Smity42
Stoopid pintaras...
Got home from work yesterday and noticed my brake lights were stuck on :D. Don't know when it started, but presumably it was yesterday sometime or my battery would have been flat yesterday morning.
Fortunately, all the inconsiderate, uneducated, and generally incompetent drivers of Brisbane somehow managed to avoid running up my a*se despite having no indication of when I was stopping :bigthumb:. Good job, team!
So I got out my multimeter ready for some HK electrical diagnosis. After doing some Houdini tricks I managed to unplug the switch that triggers off the brake pedal. Lights go out. Then I used a bit of wire to bridge the contacts, lights come back on. That settles it then: the switch is faulty. Out I go to the ute, perform some even more impressive Houdini tricks (since it is parked beside the house and you can’t open the driver’s door) and manage to get the switch out of it. Back to the coupe, but as I go to remove the switch from it, I notice that there is a hole in the brake pedal where it should be triggering the switch. So basically, the pedal is not actually pressing on the switch. Well that explains it, there’s obviously meant to be something in that hole. I found half a dozen pieces of rubber in the foot well that almost re-assemble to form a rubber stopper. That would be it! BACK to the ute now, more Houdini tricks to remove that rubber stopper this time, then again to put it into the coupe. Fixed!
Profit.
Im here ... Does that count or have I been kicked out for my lack of presence at the BnR meets :)
No, but if you don't start turning up again soon you will be! :D
Good morning!
mang.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
