Yo.......... didn't get that post before. Nah I'm going to bed righhhhhhhht meow. Gotta be up early. Hope the ice cream was good!
evening all, the tatooed GTR is sweeet, sooo much work. not so much the lambo, just cant see someone setting to a lambo with a paint pen.
on another note, any weekly meetings going on around here still? will be in brissie for the next few weeks and keen to actually catch up with some of you guys and gals.
another pike from me. sorry boys
got given a case of actual french champagne as a wedding gift that we decided to get through tonight.
mission accomplished
night bitches
random breath tested tonight...... twice good thing i decided not to DD tonight.
Oh and Andy i like boobs, don't tar us all with the same brush.
and @ little korea boy.
Holy crap that's impressive for a guy to be able to sing that song so well, and still sound like a guy! I was thinking it was going to be like that huang guy from idol or something, just a complete abortion... but holy damn. Impressed!
And yes, it does look a lot like Tas. Karaoke at the workshop? lol
shoulda suspected something was up when I found a whitney CD in his car. nga's been practicing on the sly while touge'n.
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
