it's the getting to the gym/starting a work out that f**ks me up. I just never start because I'm a terrible procrastinator.
yeah im a bit the same
i was told this shit would get fun after a while
Stick at it... who do you go with? And when? It's always easier with someone else.
Hahahaha me too... which is why I signed up for boot camp, I'm in the 3rd week of this one, it goes for 5 weeks. Monday, Wednesday and Friday I'm up at 5-ish am, leave, pick up my friend on the way, and start at 5:45.
I did it for a few months last year too, in the dead middle of winter... yeouch. You can really surprise yourself with what you're capable of if you put your mind to it, and have appropriate motivation - in this case, having a group of people, including a best friend, running around with me freezing our titties off did it for me.
That's only true for people who get high on endorphins. I'm not one of those people. I hate gyms too.
<3 it and <3 it
Gym is fun.
You just keep getting cooler, sir.
morning mangs
scrackin ?
mornin'
I wont be able to make it tonight =/
... And now to go catch a bus to work.
soft :down:
I go with Anna each night
Im down for exercise, Like i loved rugby training, when im focussing on somthing else i dont even think about the fact im exhausted and can run forever, but just doing stuff for the sake of doing it shits me. Might have to take up rugby again
Maybe we should organise 1 day a week to get together and have a run or something ? I've seen some people getting together in the park and doing some weight training.
:down: ?
:down: ?
What i really want to do is find some people to play some touch footy or something of a sunday afternoon!
could be good
Can we make it a mixed team ?
Although then there would be heaps of touching and not much running...
In.. :down:
Cool! We can make it a mixed team, I dont propose we make an official team, just a bunch of people turn up of a sunday arvo in a park somwhere and play, at school we would do this all the time we would play league rules and use peoples shoes to mark the field lol
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
