Cool! We can make it a mixed team, I dont propose we make an official team, just a bunch of people turn up of a sunday arvo in a park somwhere and play, at school we would do this all the time we would play league rules and use peoples shoes to mark the field lol
We could play red rover too
Preliminary Rollcage Ideas (courtesy of a picture off the internet and MSPAINT)
Green bits will be included if they are affordable and allowed under CAMS (nothing about them in sched. J of the cams manual though)
Purple bit will only be included if its cheap and the cage builder tells me its worthwhile.
Not sure which way to go with side intrusion yet. If double, apparently the old school X is not strong at the join, it needs to be gussetted or use two bent pipes welded together instead.
If single, I think I prefer it running right back to the harness bar as it doesn't create a bend point halfway up the main loop then...
What about the ladder style side instrusions? And the purple bit is the other bar to make the roof cross/X right? Would of thought that would be pretty standard for a cage builder to deal with ie not that expensive? Stuff penetrating the firewall is generally more expensive and difficult from what I've seen/read about on the internet.
I would prefer the two bent bars for the side intrusion but it's not like it's door to door racing so you're not likely to have anyone come crashing through your drivers door.
Squares are bad. Triangles :ninja:
Yeah, but I think the second part of the "X" is redundant here. Leaving it out will save weight and probably cost. Unless the engineer tells me its important its gone.
Yeah, but it also gives the most benefits for chassis rigidity. If its allowed by cams and not stupidly expensive, I'd like to include it.
Yeah I havend decided yet... the two bent bars would be best but the single bar would be lighter and probably enough. Unless I decide to use it for rallying and then I'd want the double bars.
I'm also tossing up wether to put a harness bar on the main loop as well so I don't have to run them right to the back...
wow there is a blast from the past
that got banned at out primary school due to injuries lol
Or force em back with the footy
great days... great days
Triangles obv > squares agree was just throwing it up as another option.
Most of the cages I've seen either have an X or a V in the roof. If engineers reckon it isn't needed I'd leave it out but I'd always want that extra protection if a roll over happens
Definitely better for rigidity but I only ever see it on the more serious cars which makes me think it will probably be prohibitively expensive.
Have a look at how Risking on here does his cages. He has the harness bar in the main hoop aswell I'd rock it like that if you can
Yeah found this thread, it's given me a few ideas for changes.
I might go with the V roof, it looks pretty strong (triangles) and not much more weight than the single bar
so who's coming tonight?
Martin & Dan will be westward bound for project alfa and thus be late.
I don't want to be just sitting there with my dick in my hand for 2 hours... so who else is coming?
league rules wins = epic grubbers and 5th tackle plays
Yeah football with out kicking is a bit shit, The only real problem you get is knock ons, leads to some interesting convos, so perhaps league rules with one touch rule, that being if the ball hits the ground its a turn over.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
