whats he want it for? discount for crazy-ass plans :)
power the tractor?
or a coffee table?
Need it to power the auger on the tractor. The diesel is no good.
left hand side of the steering wheel in the GTRs I would assume the others would be the same? A lot of people use that space for turbo timers etc that fit in there.
Nah, there was a switch there on my original panel. The clock was in the cluster somewhere, but I can't remember where. Just wondering if I can make mine work by lengthening the wires from the original spot. Half of the plugs fit into things, but don't power what they plug into (clock, torque gauge etc). So I need to find ways to make them all work.
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
