speaking of balls... who's coming this week and should I even bother bringing the hippos again?
that's what she said ?
or isn't that appropriate ? :(
hippos.. yep in.
then next week monopoly :(
sad baskins news
morgan has had her hours cut down so won't be there for a few weeks.
should we make a picket line ? or boycott ?
picket line. if we boycott we don't get to see the other cuties.
Now - I already have to do 2 copies of Wangan Midnight (the live action movie from last year). So if anyone else wants one, speak up before I do them so I can make sure I have enough discs before I start.
i'll grab one :(
Afternoon guys!
Martin - if I bring Tarlae to baskins one night what's in it for me? :)
Jason - I'll put that house sticker on my crappy laser! Funny as
Tristan - smile for me baby
That's all I've got for now
i'll grab one :D
+1
Afternoon guys!
Afternoon, mr coils
What do you want? :)
Do it!
...and come to baskins!
That's what she said
you'll probably have to bite the bullet and go to some of those silly clubs that ravi goes to with the girls
I was waiting to hear that :)
It's far more likely, cause I won't be able to come to a baskins night until May anyway.
Plus...... booooooooze :) World's best social lubricant.
Not great as any other form of lubricant though.
How crap ?
89 KE laser..... good condition though!
She's about to be my work horse while I sell my 33 and save for an S15/R34
Edited by mosquitocoils
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
