Yeah I could do that, but at the same time this car will keep going forever after a bit of TLC, so I might as well do it right the first time.
That's so unlike me, I'm always about the quick fix, just get it good enough.... what the f**k's going on!!
too much laser love
Edited by Smity42
Mangs. Just checking in from an Irish pub with free wi fi in Dubrovnik.
Cars of interest spotted in Europe so far:
one 180sx in Rome, but I think it may have been it's American cousin the 240sx.
And one four door 35 with infinity badges.
And lots of vw's
not when it comes to Fords ;)
Fords are awesome ;)
And lots of vw's
needs more beer :)
needs more beer :)
I am working on it. Beers here are $2 for pints.
Almost as good as hong kong, $5 for a four pack, sold at 7eleven and petrol stations
And lots of vw's
having fun bigfella?
Having fun, but as for hot beer wenches, can't quite give them the attention they deserve as my wife is with me at almost all times.
But as a general rule, Croatia seems to be filled with stunners.
Not like Serbia.....
lol - I knew something had been missing on this forum for a while. The good ol' serbia bashing :)
Dan_B:
I got this message from a dude on Boostcruising about a VG30DETT:
Hey mate i found out about the motor for you, it comes with everthing, turbo's ect. except no wiring harnes. It has dropped pressuse from one of the cyclinders but he dosen't know which one???? Apart from that he said it runs great. He said the price is $600 Neg.
What do you think?
Edited by Isola
Agree on the no. f**k the VG. Oh and as I said to John last night. f**k YOU GUYS. Burn Notice is awesome and I ended up going to bed at 2am last night because I couldnt stop watching them. Now I've got to stay in work and do my uni assignment because I know if I go home I'll never get anything done lol.
But Dan might know how to work some VG magic :blink:
Well, I question old mate's diagnostic technique.
He says:
now by 'dropped pressure' I would assume that means no compression? But how he tells it has no compression in 1 cylinder without testing them I don't know, and if he'd tested them he'd know which one it is. If its actually got no compression on 1 cylinder, forget it, its f**ked.
IF he actually means "not firing" on 1 cylinder then it could be something simple causing no fuel or spark to that cylinder, in which case it would probably be a very easy fix.
I would suggest, if you have any intention on buying it, do a compression test on it first and if the cylinders aren't all in spec and fairly even, then stay far FAR away, it's not worth the hassle.
If you can get the VG for like $400 I'd say go for it, if a cylinder is f**ked rebuild it yourself :D
The laser's now rolling on some sweet nolathane bushes in the front ;) oh yeahhhh
    • I did basically the same procedure on a ZF6HP but the reason to pull the valve body is to replace the seals between the valve body and the transmission which are notorious for leaking pressure with age causing poor shifting and burning out the clutches. If you just wanted to exchange all the fluid you should be able to undo one of the transmission cooler return lines to drain into a bucket while using the pressure filler to keep it topped off.
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
