must...resist...urge...to...say..."that's what she said"
indeed
F*ck im bored, I could be doing so much more usefull stuff at home today. This time next year im taking my long service leave, perfect holiday weather imo
Depends where you go on your holiday...
this will be an around home holiday, at present i would kill for a week or two bumming around home doing nothing
I did a week and a half of that over easter :)
nice, i never have bulk leave, i always waste in in days here and there...but with long service leave i have no choice so im looking forward to it lol
I only had to take 4 days off to get a week and half break pretty much. A much needed break ;)
only because they're standing in the rain after the alfa breaks down :)
ROFLMAOCOPTORWTFBBQ
Flu shots = mind control. I just get the flu instead of letting the gubberment give it to me.
Unfortunately with my asthma, if I get the flu it knocks me out for ~6 weeks. And then I catch everything else until late December. When I get the shot I get a slight sniffle and headache for 3 days, then nothing for the rest of the year :)
I agree. Pick up more guys in a skyline than chicks. I doubt there is any car in the world that makes chicks wet. Chicks like cars because of what the represent. IE Guy driving a ferrari. Has a dickload of cash. Guy driving 20 year old nissan. ermm...
Pretty true, but I'll tell you I never got a single look from any girls, guys, frogs or dog turds driving my AU falcon around.
Skyline + zorst + bov.... well... you get the idea. Any publicity is good publicity!
Oh and it is a universal truth that all skyline owners are knobs.
Unfortunately this seems to be true. I just grit my teeth and bare it, then remember how much fun it is to hit boost, and all of a sudden I stop caring hahaha.
Rule 2 still applies. if he was wrong about the seats then he was right about being inaccurate and vice versa.
It's too early for this
It's STILL too early to deal with that statement.
That's what she said
Unfortunately with my asthma, if I get the flu it knocks me out for ~6 weeks. And then I catch everything else until late December. When I get the shot I get a slight sniffle and headache for 3 days, then nothing for the rest of the year :D
I completely agree. Can't say enough good things about flu shots, obviously other than that things in the news about people dying/getting sick or whatever. Asthma does suck, I'm glad I don't have to deal with it but it can definately be a real big pain in the ass without taking the right precautions this time of year. More power to ya.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
