need to find a laundromat in paris. running out of shit to wear.....
I knew she was a broad minded person but c'mon, surely she ain't big enough in there to open a laundromat?
She's already got a bakery, fruit shop, antique dealer and dominos in there...
i think dark knight is a prety cool guy. eh fights star wars and dosent afraid of anything
Darth Vader would force choke the shit out of Batman, true story!
I missed something here didn't I
Anyone up for trivial pursuit tomorrow ? Kids version only. No cheating. You cant phone a friend either.
Hippos is out, the orange one called in sick. Apparently it's on a diet and balls aren't good for it.
I just checked the box.. and it's not a kids version... but it is on dvd however... so no pie... sorry.
damn you and your box *shakes fist*
hippos = out?
trivial pursuit = out?
I get the feeling Batman would be immune to the force. He just strikes me as that kinda guy :)
how exactly i one immune to the force? Sure he might not fall for mind tricks but if someone used the force to drop a f**king house on his head he is still in a spot of bother
yeah... but... it's fucking Batman!
and Jason, no one said hippos were out.
LINK FOR MISO!
that should help ya miso....
Cheers Dan,
had a look and none are really close to our joint.
decided i am going to rough it out till new york.
anyone got any reasonable shopping requests from new york or la? preferably new york, as i am only spending three days in la, and they are pretty booked out
on a sidenote, if anybody has any spare time, am in the hunt for a new vehicle
has to be a 2000 plus model
four doors
and automatic with under 100 xxx k's
price range is 10 - 15k.
at the moment a 07 current model lancer is winning the race, as at 14k it's a decent enough car and has another 2.5 years of warranty left
feel free to throw a spanner in the works
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
