:(:):):D
BOV is wound all the way in and it still stalls.
Joyish moment today, upon inspection have found that power steering reservoir is floating free. Am missing some nuts. Oh joy of joy
so im assuming from the silence here that phil has run out of fuel on the way home? or did martin installing the solenoid correctly fix the issue?
Also, john we did not hear enough bov
pffft run out of fuel... I was just lucky it didn't wreck or explode :) . Bit over one bar ( thats what she said ) see how we go tomorrow
Would you like to borrow one of my stock BOVs? It'll get rid of your flutters like you wanted.
Yeah... pipe didn't work. Did some roadside tuning (read: ripped the cunt off) after dropping off Colin. Needs a tiny bit more tweaking tomorrow. I'll just run it as is, should be fine.
Dan = grace
Dan != Grace. Not in any way :P
i wouldn't leave the house if that was the case.....
lol
yep resetified it when i got home.
That's what she said?
Any rush for these parts Tim ? I won't be able to get them done until tuesday next week :D
No rush Phil, no rush at all.
Werd
Morning mangs scarnon ?
Morning mang.
Counting down for the weekend. Scarnon with you?
gettin` jiggy wit it
Keen for German Club on wed night? (Origin night)
Morning mangs...... how was ye olde ice creamery?
@ Jason......... I'll give you a bit over 1 bar. Also don't be held back by your pipework hahaha go to supercrap and scour through all the radiator hoses til you find something that you can cut, or will bend to suit!
I'll also have those extractors this weekend hopefully so hopefully can get done at the same time as Tims?
Also wouldn't the german club be packed for origin? I'd say any drinking establishment within Brisbane would be... especially with food :P
Dan != Grace. Not in any way :D
lol
Werd
Morning mang.
Thats good then. Should have them all done and dusted on tuesday arvo. Did you want them early or just bring them on thursday ? I've never been to the german club. Are you allowed to mention the war? :D
Keen for the bar. :P
Pffftttt couldn't be arsed. I'll just saves up some monies and get someone to fixafy it for me. I'll have to ask the fitter if he can do it at the same time. Might cost you some beers :)
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
